Ansys Learning Forum Forums Discuss Simulation Photonics Problem on recording the E field in 2d polarizer simulation Reply To: Problem on recording the E field in 2d polarizer simulation
Amrita Pati
Hi Xuan,
Thanks for sharing the code! I did try to reproduce the issue but some of the input parameters like height, period etc. are missing. I used random values and in my case most of the light is transmitted, which I can see in the movie monitor. Would you be able to share the values of the missing input parameters so that I can recreate the exact simulation. Also, which release of Lumerical are you using?
Amrita
