Ansys Learning Forum Forums Installation and Licensing Ansys Products speed up the job in hpc (mpp) Reply To: speed up the job in hpc (mpp)
Reno Genest
Hello Rajesh,
The command line seems fine; you ran for more than 7 hours on 147 MPP processors.
The EM solver part takes most of the calculation clock % time. Your EM timestep before the license problem was 5e-8 second. This is quite small. Did you specify this timestep using *EM_CONTROL_TIMESTEP? Could you increase the EM timestep to reach your termination time faster? Note that if you have structural parts, the solid mechanics timestep should be smaller or equal to the EM timestep.
Reno.
