Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › LS-RUN freezing › Reply To: LS-RUN freezing
December 26, 2024 at 7:18 pm
Hello Shawn,
I thought that resetting the computer to factory settings solved the problem.
You already have a workaround; running LS-DYNA using command lines in command prompt. So, this means that the LS-DYNA solver works on this machine and processors.
LS-RUN is a very light application; all it does is it takes the input from the LS-RUN GUI and converts it into the command line in the "Preview" field. Then, LS-RUN sends the command line to the shell in the background.
Reno.
