Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Problem on recording the E field in 2d polarizer simulation › Reply To: Problem on recording the E field in 2d polarizer simulation
xuanlunhuang20
Hi Kirill,
I use the "SiO2 (Glass) - Palik" material for the substrate. For 940nm, it's about n=1.45.
As I mentioned in the reply to Amrita, I use the "s_params" group to record the reflection, it's ~97%. I also set my own moniter "myR" in the same simulation to double check, it's ~97%.
Following your suggestion, I redo the simulation with only the source, transmission monitor and reflection monitor. The result is the same.
