Ansys Learning Forum Forums Discuss Simulation Electronics synchronous machine simulation in 3d Reply To: synchronous machine simulation in 3d
GLUO
1.When I rotate the rotor at 1800 RPM, the rotor flux decreases, leading to incorrect results.
Could you let us know how did you check the rotor flux? Mag_B on rotor pole? It decreased, compared to which condition?
2. Additionally, even before defining a motion setup for the rotor, when the speed is set to zero, the flux from the rotor windings appears to be incorrect.
What is your rotor winding setup?
I would recommend go to File>>Open example>>RMxprt>>synm3>>bjs7 , analyze the sync motor example, right click to generate a Maxwell model, and compare your setup with the example model.
GL
