Ansys Learning Forum › Forums › Discuss Simulation › Process Integration and Design Optimization › Creating Fluent Web Apps using optiSLang 2021R2.mp4 › Reply To: Creating Fluent Web Apps using optiSLang 2021R2.mp4
December 20, 2024 at 7:49 am
Hi Charles,
Sorry for the late reply. Regarding the Error messages you are showing: The responses like “temp_outlet_uniformity_op” are coming from the ETK node that tries to read the “output_parameters.txt”. So, it seems that this file is missing.
In the pictures you share, you see a path. This is where the app is executed. You can browse this path and check if this file exists.
If it does not exist, please revisit the fluent journal. At the end of the script there is a command to export the "output_parameters.txt" and may adjust the command.
Then run the project in optiSLang and see if the "output_parameters.txt" is created. If this is the case, you can export a new app and check again.
Best regards,
Markus
