Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Wave Elevation Input and Data Export for Generated Wave in AQWA 2023 R1 › Reply To: Wave Elevation Input and Data Export for Generated Wave in AQWA 2023 R1
December 19, 2024 at 2:14 pm
You can add the Wave Surface Elevation result to the Solution after completing the Hydrodynamic Response analysis. In the detail panel of "Parameters Vs Time," where the wave surface elevation is located underneath, there is an "Export CSV File" option that allows you to export the wave surface elevation results. These results represent the incident wave elevation without considering diffraction or radiation effects.
