Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Slanted bottom level › Reply To: Slanted bottom level
s.m.mousavi
Thanks for the reply.
1- Where/how can I check the "what the maximum permitted step size is"?
2- "If you're wanting a surface height you can also monitor...", again how? Should I choose something like facet and then max facet speed or what?
Could you please assist with those questions?
