Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Slanted bottom level › Reply To: Slanted bottom level
I think it'll pick the nearest time step, so you may want to check what the maximum permitted step size is.  If you're wanting a surface height you can also monitor, plot and save that directly as you run the model: look at the Report function.
