Ansys Learning Forum Forums Installation and Licensing Ansys Products Ansys student software installation issue Reply To: Ansys student software installation issue
Deepak
Please verify that there are no errors present in your geometry.
Do you find the same issue if you try to create a new model (Simple cube) from scratch?
Can you try the following suggestions made in this forum discussion:
An error occurred inside the SOLVER module: general error (Reccurent problem)
“An error occurred inside the SOLVER module: general error” when resolving model
ERROR: A general failure occurred during the solution process.
Thanks,
Deepak
