Ansys Learning Forum Forums Discuss Simulation Fluids ansys aqwa : connector Reply To: ansys aqwa : connector
Mike Pettit
The Aqwa Reference Manual gives you information on the Aqwa input file contents. Specifically, DCON defines the position of the joint and the number of locked rotational freedoms; KCON and CCON define the joint stiffness and damping terms about the unlocked rotations; and FCON defines the joint friction coefficients.
In Picture 1 you have two hinge joints (DCON    2) and two rigid joints (DCON    3). The hinges have zero stiffness, damping and friction defined.
In Picture 2 you have two ball-and-socket joints (DCON    0), with zero stiffness and friction, and with damping of 4.0E+09 about the joint Z axis.
I hope this helps!
Mike
