Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Slanted bottom level › Reply To: Slanted bottom level
December 19, 2024 at 9:19 am
Hi Rob!
I followed your suggestion to decrease the time step. I set the Adaptive time step with CFL = 0.35, and initial time step size = 1e-5 (s). Fortunately the solution has been converged.
I have another question: I set to save the outputs every 0.15 (s) of the flow time. However, there are some time intervals, that the outputs are not saved at each 0.15 (s), but they are saved in bigger time intervals. This makes the output look like with some missing data. How can I make sure that Fluent will save every 0.15 (s) of outputs?
