Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Transmit boundary – reflection / perturbation of pressure waves › Reply To: Transmit boundary – reflection / perturbation of pressure waves
December 18, 2024 at 3:41 pm
Actually, for compressible materials, its sound speed may not be a constant. It should be related to dp/dr, where p is pressure, r is density. You can do a contour plot of sound speed to check its magnitude.
If the problem still persist with new Flow Out BC, you need to extend the Euler domain.
