Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › speed up the job in hpc (mpp) › Reply To: speed up the job in hpc (mpp)
Reno Genest
After you make sure you run on 32 cores, you can try to bind processes to cores and see if you can speedup the calculation further. I found the following in our knowledge database:
By default, an MPI process migrates between cores as the OS manages resources and attempts to
get the best load balance on the system.
But because LS-DYNA is a memory intensive application, such migration can significantly degrade performance
since memory access can take longer if the process is moved to a core farther from the memory it is using.
To avoid this performance degradation, it is important to bind each MPI process to a core.
Each MPI has its own way of binding the processes to cores, and furthermore,
threaded MPP (HYBRID) employs a different strategy from pure MPP.
I.  Pure MPP
To bind processes to cores, include the following MPI execution line directives according to the type of MPI used.
HP-MPI, Platform MPI, and IBM Platform MPI:
	-cpu_bind or -cpu_bind=rank
        -cpu_bind=MAP_CPU:0,1,2,...   <<<< not recommended unless user really needs to bind MPI processes to specific cores
IBM Platform MPI 9.1.4 and later:
	-affcycle=numa
Intel MPI:
	-genv I_MPI_PIN_DOMAIN=core
Open MPI:
	--bind-to numa
Let me know how it goes.
Reno.
