Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Data Extraction From A Rake › Reply To: Data Extraction From A Rake
December 17, 2024 at 10:23 am
Have a look at xy plots. You can save the data to file rather than plotting. You really don't want to do that at every time step, but you can also use Execute Commands (I suggest using TUI commands as the GUI macros require VERY careful panel selections) every some time steps.Â
Alternatively, you can use points rather than a rake and monitor each point value, saving that to file. In Excel you can then combine all of the points to plot point v time; rake at single time etc.Â
