Ansys Learning Forum Forums Discuss Simulation Fluids Slanted bottom level Reply To: Slanted bottom level
If reducing the wave height works it's because it's removing a model instability, reducing the time step will reduce the impact of the instability on the solution hence me suggesting it. Note, the step might become very small. You also need to check the cell size and shape as the wave enters the domain: how many cells are across the amplitude and how low is the aspect ratio.Â
