Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Thin-walled tube Meshing › Reply To: Thin-walled tube Meshing
December 13, 2024 at 3:08 pm
peteroznewman
The element size is too large. Where is shows 20 mm use 5 mm. On the Resolution line where it says 2 use 4.  Smaller elements and higher resolution will smooth out the mesh.
