Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Rivet and double riveted joint › Reply To: Rivet and double riveted joint
December 13, 2024 at 2:07 pm
Thanks for the clarification. Also IF we consider Butt joint, we should use 'Extract' option in spaceclaim to convert rivet into line body, right? in this case, we will have to remove rivet head and tail parts, right because those parts wont be converted into 1D.
