Ansys Learning Forum › Forums › Discuss Simulation › Photonics › How can I use the Bessel Gaussian beam source in fdtd? › Reply To: How can I use the Bessel Gaussian beam source in fdtd?
Hi,Â
Thanks for the question. The available built-in sources are Gaussian, plane wave, and Cauchy/Lorentzian, so you will probably have to build a custom source to do this. One approach would be to define custom spatial field profile as a Matlab dataset and import it. Or, if you have a model of your beam from Zemax, you can import it a Zemax ZBF file. Please see Import source - Simulation object – Ansys Optics for more information on importing custom sources.Â
Alternatively, if you know how to decompose your Bessel Gaussian source into plane waves, another approach would be to use a summation of plane wave sources to build up the custom source.Â
Best,
Anna
