Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › methode pour insérer une macro ApDL dans du python › Reply To: methode pour insérer une macro ApDL dans du python
ashish.khemka
Translated: Hello, I have to do an XML program integrating python for a fsum post-processing of a group of nodes and related elements. Indeed on mechanical the result is not correct because it makes an average between the connected elements of 2 bodies. To achieve this, I have to use an apdl macro and I would like to be able to use this macro in a python and be able to display the torsor on mechanical. How can I integrate APDL into Python? What example can I use if I fail? thank you in advance for your help
