Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Looking for Example Custom Materials Source Code › Reply To: Looking for Example Custom Materials Source Code
Dimitris Polyzos
I will be happy to help you with your query. For start, two photon absorption is a non linear phenomena and I reckon that you need to use a chi3 model, as you correctly mentioned. There are a couple of material models using this  such as: Advanced and custom optical material models in FDTD and MODE and Flexible Material Plugin Framework. Please keep in mind that non linear simulations can be quite tricky to setup.
Some application examples that use non linear materials can be found here: Nonlinear-optics-list-of-examples
I hope I helped.
Kidn regards
Dimitris
