Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › access to path files denied error › Reply To: access to path files denied error
December 11, 2024 at 5:42 pm
Hey
Can you check out this post once, Unable to save Workbench projects
Session files error occurs sometimes when you are synching the project folders to the cloud.
Here are some suggestions that may help during the session file access issue from one drive,
- You can pause the OneDrive syncing and then try to work on the files. (this has worked in many cases)
- Stopping and restarting or re-synchronizing the OneDrive process might also resolve this problem.
- If possible, save or move the files to a local disk.
Thanks,
Deepak
For more exciting courses and certifications, hit this link:Â Ansys Innovation Courses | ANSYS Innovation Space
