Ansys Learning Forum Forums Discuss Simulation Photonics How to implement 50 Ohms output impedance of a PD? Reply To: How to implement 50 Ohms output impedance of a PD?
m.belchovski
Hi Kyle,
Thanks a lot for the clarification. I have a follow up question. I want to measure the power spectrum of the output, however in the Spectrum Analyzer I do not see the option to show the power at 50 Ohms termination? The power meter is adjusted to show power at 50 Ohms from a voltage signal. But the spectrum analyzer does not have the option? Do you have a workaround for this problem? Thanks a lot once again.
