Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Issue with embedded sensor in Ansys ACP Pre › Reply To: Issue with embedded sensor in Ansys ACP Pre
hasnain09102
It sounds like the issue might be due to the sensor elements not being properly coupled with the CFRP layers. When embedding sensors in a CFRP sandwich structure, ensure they are defined as part of the same element set or connected using appropriate adhesive or bonding elements to ensure they bend with the structure.
