Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Different results for inlet boundary conditions. › Reply To: Different results for inlet boundary conditions.
venkyvenkatesh374
Thanks for the reply sir., I did the same how yu've mentioned. for some reason the results are different.
Also I tried another method, where I've set a user defined coordinate frame which is tilted to specific angle of attack. Now while solving the case Ansys uses default coordinate frame. Anychance do you know how to set the user defined coordinate frame while solving the case.
