Ansys Learning Forum Forums Discuss Simulation Fluids Different results for inlet boundary conditions. Reply To: Different results for inlet boundary conditions.
abhishek.roy
When titing the geometry if you want to maintain same AOA the chord of the wing should be rotated with respect to horizintal axis. If the wing is twisted titling might make it difficult to get desired AOA. Usually velocity component approach is preferable.
