Ansys Learning Forum Forums Discuss Simulation Fluids Point exception in erosion calculation Reply To: Point exception in erosion calculation
javat33489
OK, from the image you can see the problem. Given erosion is a function of parcel mass and facet size what do you think you can do?
-Sir, do I need to reduce the parcel mass?
Sir, did I set the condition correctly?
At the input, I set 53 kg/s of water, I also needed to specify that half of this solution is proppant and I specified the number of particles 25 kg/s:
Will this mean that the total volume of this mixture will be 53 kg/s (28 water, 25 proppant particles)?
