Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Spaceclaim merging faces issue › Reply To: Spaceclaim merging faces issue
Keyur Kanade
You can use Fluent Meshing to generate surface mesh with this geometry. Then you can use improve surface mesh task to improve surface mesh which will help you to get good mesh at that position.
Avoid merging faces in SpaceClaim. It may give issues in meshing.
Please go through help manual for more details
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
