Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › d3crack file not valid › Reply To: d3crack file not valid
December 3, 2024 at 4:25 pm
igandiko
Hello, are you opening d3crack file directly in LSPP? You may have to load the d3plot database first and then select File > Open > Crack file to open the binary crack database.Â
(or) you can open the database using the execution command below,
lsprepost d3plot q=d3crack
Please use the latest LSPP build (4.7 is quite old).Â
