Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Workbench LS-Dyna – Bodie penetrations during droptest › Reply To: Workbench LS-Dyna – Bodie penetrations during droptest
Hello Douk,
If the geometry you use has two or more bodies in contact, a Body Interactions object folder appears by default under Connections in the tree. Included in a Body Interactions folder are one or more Body Interaction objects, with each object representing a contact pair. If this is not turned on, can you add this manually?
For more detailed guidelines on using body interactions, please follow this link: 3.2. Body Interactions in Explicit Dynamics Analyses
This should handle contact penetrations smoothly, please let us know if this is not helping.
Nanda.
If you are not able to open Ansys help links, refer to this forum discussion: How to access the ANSYS Online Help
Also, we launched a public help documentation website: Ansys Help
For more exciting courses and certifications, hit this link: Ansys Innovation Courses | ANSYS Innovation Space
