Ansys Learning Forum Forums Discuss Simulation 3D Design Using probe on ansys discovery Reply To: Using probe on ansys discovery
Subashni Ravichandran
You can create a point at the center of the Sphere and create a custom monitor at the point location.
To create the point, you can use the 3D point tool under Design Tab > Create,
Check out the below Knowledge article for tips on creating monitors.
Discovery Quick Tip- Monitors on Construction Geometry | Ansys Knowledge
