Ansys Learning Forum › Forums › Discuss Simulation › Fluids › The body does not rotate. Fluent › Reply To: The body does not rotate. Fluent
November 29, 2024 at 5:24 pm
Sir, I have done this before.
Everything worked.
Maybe the old version didn't have some settings.
I made two super small test versions and attached them to the link, I would be grateful if you could take a look. There you can see that I set the rotation area and the rotation itself, but it doesn't rotate.
