mmh.rakin
In my model half of the yield stress causing pressure is not showing any significant k1 result even the crack surface almost intersect the solid. but if the internal pressure is increased to 90% of the yield stress causing pressure then it show good result with thw increment of the  crack surface size. why is that?
