Ansys Learning Forum › Forums › Discuss Simulation › Fluids › ROTOR DOMAIN MESHING › Reply To: ROTOR DOMAIN MESHING
aagalvez
Hi rob. Thanks for your reply. The min ortho quality for the rotor mesh is 0.2569 while the max skewness is 0.8319. Other domain (stator outlet and inlet) meshes linked with this domain tends to have the same min ortho qual equal to approx 0.25 (for outlet) and 0.5 for inlet. Skewness are lower for the other 2 domains around 0.5 value. Is this good? Thank you.
