Ansys Learning Forum Forums Discuss Simulation General Mechanical Bolt pretension setup validation Reply To: Bolt pretension setup validation
Gary_S
Applying Bolt Pretesnion using a Load (force) with non-linear contact can be very difficult to converge.
I would apply the pretension as small Length (distance) to make sure your contact is set correctly. You can read the resulting force as needed.
