Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › need help with rotor simulation — solver did not run › Reply To: need help with rotor simulation — solver did not run
harrygross616
It sounds like the issue could be with the setup or compatibility of your inputs. Double-check the boundary conditions, material properties, and meshing to ensure everything aligns with the tutorial. If the rotor acceleration curve was skipped or modified, it might be affecting the simulation.
retro bowl
