Ansys Learning Forum Forums Discuss Simulation Fluids RADIAL DYNAMIC PRESSURE DISTRIBUTION IS INCORRECT? Reply To: RADIAL DYNAMIC PRESSURE DISTRIBUTION IS INCORRECT?
Petros
Can this be due to the wake created by the rotor hub? This would mean a slower moving flow in this region, compared to the toroid region after the blades.
You can do a vector plot on a ZY plane and see how the flow behaves after the impeller.
