Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How can I run specific solutions at the same time??? › Reply To: How can I run specific solutions at the same time???
November 25, 2024 at 1:30 am
If you clicked Update Project, analysis D would not solve again, because it is completely up-to-date.
If you did not want analysis B to solve for a while, but don’t want to delete it from the project, you can insert an APDL command object to issue the NCNV,2 command which tells Ansys to terminate that analysis. That way, systems A, C and D would update if needed and system B would not. When you want B to solve with the Update Project again, simple suppress the APDL command object.
