Ansys Learning Forum Forums Discuss Simulation LS Dyna Problem with restart LS-DYNA & PolyUMod Reply To: Problem with restart LS-DYNA & PolyUMod
Dennis Chen
Valerym, I suspect the d3plot load curve issue is related to the value of IOOPT parameter of the database_binary_d3plot.   In the k file you sent, it's set to default but maybe try setting it to 2 and see if it works as intended.   Just a thought, I've not tested it.
