Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Point exception in erosion calculation › Reply To: Point exception in erosion calculation
November 22, 2024 at 11:15 am
Which means each parcel is around 25/170 kg/s which is a lot of mass hitting what I assume is a small facet. Try using stochastic tries in Turbulent Dispersion, 10-20 may be suitable to reduce the parcel mass.Â
