Ansys Learning Forum Forums Discuss Simulation LS Dyna MAT 295 raises severe (153) error on Windows Reply To: MAT 295 raises severe (153) error on Windows
Pedram Samadian
The error probably indicates an issue with how the material model has been initialized during the simulation. Please see the following tips to hopefully fix the issue:
  • Check if all the required parameters for *MAT_295 have been provided and are consistent with the material model requirements as per LS-DYNA Keyword User’s Manual Vol. 2 (LSDYNA Manuals).
  • Change the solver to MPP. This solver often handles memory allocation differently and may avoid this problem.
  • Check the cards used in your input deck file using LS-Prepost (the “model check” feature in the keyword manager) or a similar tool to ensure there are no syntax errors.
  • Increase the memory allocation for the LS-DYNA using the *keyword card.
  • Consider using newer versions of the LS-DYNA solver, which are available at LS-DYNA (user=user) Download Page (Username: user & Password: computer).
I hope these suggestions are helpful.
Thanks,
Pedram
