Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Non-Intersected faces found for matching interface periodic-walls › Reply To: Non-Intersected faces found for matching interface periodic-walls
zoelle.wong
yes.. my outlet BC is a pressure outlet. I've also tried enforcing "no-reversed" flow as a sanity check as the difference is happening between the inlet/outlet
