Ansys Learning Forum Forums Discuss Simulation Fluids Non-Intersected faces found for matching interface periodic-walls Reply To: Non-Intersected faces found for matching interface periodic-walls
In which case it should be fine. However, if the temperature is pinned to 5000K there's something not working right. How do the energy fluxes look in each case?
