Ansys Learning Forum Forums Discuss Simulation Fluids Non-Intersected faces found for matching interface periodic-walls Reply To: Non-Intersected faces found for matching interface periodic-walls
zoelle.wong
Yes - mass flow sector is sorted out. Without the heat sources for both the periodic and fully-revolved cases, the results match. I'm not sure if its a boundary condition problem if my cold flow cases match :(
to make the periodic interfaces, I first separated the domain, then created the periodic interfaces.
