Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Non-Intersected faces found for matching interface periodic-walls › Reply To: Non-Intersected faces found for matching interface periodic-walls
And you've sorted out the mass flow for the sector? If so I'd expect the temperature field to also make sense.
The only oddity is having two zone 17 for periodic. It's usual for Fluent to give everything a unique ID.
