Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Incorrect velocity streamlines and observed velocities profile › Reply To: Incorrect velocity streamlines and observed velocities profile
msm19b039
’You’re diffusing the result out too much’ can you please take a couple minutes to explain this? Does this mean the infomation diffusion is taking place over big sized cells instead of numerous small cells? can this be considered to be the equivalent of high courant number issue in the case of transient simulation?
’Repeat until it stops changing’ Until what stops changing? how to judge?
Your response is much awaited.
Thank you
