Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Incorrect velocity streamlines and observed velocities profile › Reply To: Incorrect velocity streamlines and observed velocities profile
Now look at the cell resolution at 1.5m below the blades. You're diffusing the result out too much.
Have a look at the various examples and see what they used in the paper. Try using adaption over a cylinder starting just above the mrf, that's a bit bigger than the mrf and extends below the measuring point. Refine & run. Repeat until it stops changing. To accurately model airfoils you need to consider y+, significant levels of near wall resolution and high mesh resolution to capture the blade profile etc. In 3d that's not going to be a small model.
As staff I'm not able to follow links and can only work with what I can see on the Forum.
