Ansys Learning Forum Forums Discuss Simulation Fluids Non-Intersected faces found for matching interface periodic-walls Reply To: Non-Intersected faces found for matching interface periodic-walls
Yes, so you used a mass flow that's the same number in each case. What is the inlet area in each case? Use the surface integrals to find the value in Fluent.
