Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Incorrect velocity streamlines and observed velocities profile › Reply To: Incorrect velocity streamlines and observed velocities profile
November 19, 2024 at 3:24 pm
If the fan is around 1m across and your base mesh is 28cm (280mm) I'd say that was rather coarse. You can also see the effect in parts of the contour. Plot velocity in Fluent and display with node values off & focus around the fan & the reporting region.Â
