Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Non-Intersected faces found for matching interface periodic-walls › Reply To: Non-Intersected faces found for matching interface periodic-walls
zoelle.wong
Hey ANSYS team,
I have a follow up question related to this problem set up. I ran my periodic BC case and compared the results to a 2D Axisymmetric and fully revolved case. The inlet/outlet/wall boundary conditions are the same for all 3 cases. My 2D Axisymmetric and fully revolved case approximately match in terms of flow field comparisons, but the periodic BC does not.
I varied  equation of state, checked the peridodic conditions for my periodic boundary condition, but the periodic BC results did not change. My shadow/periodic faces match to be conformal
I build my conformal, periodic BC with these inputs: origin [0,0,0], axis [1,0,0], auto offset
Sometimes the auto offset is computed as +/-90 deg
Is there something that I'm missing? I haven't had this issue before so I wasn't sure if its due to the internal structures inside my domain (see below). Thank you again so much for your patience!
